Activity › Forums › VEGAS Pro › Help with Panasonic 100B 30P in Vegas 7c
  • Help with Panasonic 100B 30P in Vegas 7c
    Posted by Thomas Roberts on June 21, 2007 at 4:58 am
    Has anyone rendered 30P video from a Panasonic 100B? I am getting jaggy lines. Do I need to supersample or oversample, reduce interlace flicker, render to 24P?
    Video was shot at 30P 1/50th of a sec.
    Just want to get rid of all the diagnol lines of the jaggy lines.
    TR 16MM -Have camera will travel
    Mike Kujbida replied 19 years, 3 months ago 2 Members · 5 Replies
  • Mike Kujbida
    June 21, 2007 at 2:28 pm
    If you’re watching it on a computer monitor, this is normal.
    Burn a short segment to a DVD, play it on a TV and see if the problem is still there.
  • Thomas Roberts
    June 21, 2007 at 4:59 pm
    DVD Architect 4.0- Is it better to render to an AVI or render to DVDA file (mpeg) – I render to DVDA 4.0 format to save time. MPEG 2 setting, then use that file in DVDA to make a DVD.
  • Mike Kujbida
    June 21, 2007 at 10:29 pm
    It’s a matter of personal preference whether you render to AVI or MPEG.
    I prefer to render to MPEG from Vegas as this gives me a lot more control over the bitrate, quality level, etc.
    You said I render to DVDA 4.0 format to save time.
    What template are you using?
    I always start with the DVD Architect NTSC video stream template for video and and then modify it as desired.
    Audio is the AC-3 Stereo DVD template.
  • Thomas Roberts
    June 22, 2007 at 4:00 am
    I render to MPEG2
    -DVD Architect 24P NTSC
    AC3 5.1 stereo
  • Mike Kujbida
    June 22, 2007 at 9:33 am
    Looks good to me.
    Sony has a free PDF document on their site titled 24p and Panasonic AG-DVX100 and AJ-SDX900 in Vegas and DVD Architect that helps you with a 24p workflow.
