Activity Forums Adobe After Effects Expressions help with offset exp
  • help with offset exp
    Posted by Rod Santoyo on July 17, 2009 at 5:24 pm
    Hey there,
    Im kind of newbie at AE expression. I need help with this.
    I am making some animated mattes with a lot of vertical white bars.
    Ive already made them go up with the same animation of my layer number 1, also with an offset on X axis.
    I used this expression:
    x = thisComp.layer(index -1).transform.position[0];
    y = thisComp.layer(index -1).transform.position[1];
    [x+12,y]
    Now here is the thing,
    I cant get to offset each bar start frame so I can get a “wavy” effect, like in an old sound EQ or volume digital meter)
    Help me plz!
    Rod
    Rod Santoyo replied 17 years, 2 months ago 2 Members · 2 Replies
  • Ben Rollason
    July 24, 2009 at 11:53 am
    you need to use valueAtTime()
    For instance:-
    thisComp.layer("matte_layer").position.valueAtTime(time - 3);
    will give you matte_layer’s position 3 seconds ago.
    thisComp.layer("matte_layer").position.valueAtTime(time - (3*thisComp.frameDuration));
    will give you matte_layer’s position 3 frames ago.
    thisComp.layer("matte_layer").position.valueAtTime(time + Math.sin(time*5)/2);
    will follow matte_layer’s position, but oscillating back and forth along the path.
    -Ben.
    https://www.benrollason.com
  • Rod Santoyo
    July 24, 2009 at 2:47 pm
    Hey Ben , I´ll try it as soon as I get to the office.
    I´ll let u know the result. Thanks!
    Rod
