Activity Forums Adobe After Effects Expressions help with my syntax on a source text expression
  • help with my syntax on a source text expression
    Posted by Adam Greenberg on March 8, 2022 at 5:05 pm
    Hi. various versions of the expression below works, but not as I expect. It should return my original text from the main text layer in the font that the layer is set to, and then add the source text from text layer 2 but in the font listed in the expression;
    value + ‘ ‘ + thisComp.layer(“Text Layer 2”).text.sourceText.style.setFont(“ArialNarrow”);
    thanks for any help
    Adam Greenberg replied 4 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 8, 2022 at 6:55 pm
    Sorry, you can’t use an expression to set multiple fonts in a single text layer.
  • Adam Greenberg
    March 8, 2022 at 9:24 pm
    thanks so much Dan. that officially allows me to stop researching these types of options
