Activity Forums Adobe Photoshop help with logo
  • help with logo
    Posted by Greg Ball on June 7, 2005 at 3:38 am
    I have a large logo saved as a tga file. It’s black and red. I’d like to save it as a PNG file with so I can super impose it in my NLE. How would I go about this? Thanks. Any other advice?
    Jerryjet replied 21 years, 3 months ago 3 Members · 2 Replies
  • Jeff Cochran
    June 7, 2005 at 3:44 pm
    Greg
    Does the Targa have an existing Alpha channel? If so, use the alpha to delete the background and do a save as > PNG
    If you don’t have an existing alpha, you may be able to use one of the image’s color channels to create one.
    Windows pull done > Channels. Look at the individual Red, Green or blue channels. Find one that gives you good contrast and copy, create a new channel and paste. You may have to clean it up a bit, but this should separated the logo from the background.
    Hope this helps
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
  • Jerryjet
    June 13, 2005 at 1:31 pm
    Why can you just keep it as a TGA file with embedded alpha and bring that into your Non Linear? Some people call TGA files the Truevision Graphic Files because that is who made it. It is a format specifically designed to bring in high end image sequences into NLEs with alpha. They also save very well numerically as animated sequences to be used in video and gaming.
    jerry h
    http://www.jetstreamer.com
