Activity Forums Maxon Cinema 4D Help with Lighting
  • Help with Lighting
    Posted by Greg Paterson on September 12, 2005 at 1:33 am
    I need some guidance with a lighting set up.
    The project has a plane with a DV colour video clip in the colour channel of its material.
    Above this plane is another plane with a water material and an animated greyscale clip in the bump channel to animate the water.
    There is a lot of quality loss from the original quality of the DV colour video including colour desaturation and increased contrast.
    I feel that the primary problem is the lighting.
    The best arrangement to date is two omni lights above both the planes to the left and right of the planes but not directly over them.
    Any comments on any aspect of this project would be appreciated.
    Thanks Greg
    Greg Paterson replied 21 years ago 2 Members · 3 Replies
  • Adam Trachtenberg
    September 12, 2005 at 4:36 am
    I’m not sure what you’re trying to accomplish, but it sounds like you might be better off putting the DV clip in the luminance channel.
  • Greg Paterson
    September 12, 2005 at 6:16 am
    Hi Adam,
    [Adam Trachtenberg] “I’m not sure what you’re trying to accomplish, but it sounds like you might be better off putting the DV clip in the luminance channel.”
    The final effect is an actor writng on a wall of water between them and the camera.
    Tonights experiment — the luminance channel.
    GReg
  • Greg Paterson
    September 13, 2005 at 1:03 am
    Hi Adam,
    Seems much better in the luminance channel.
    I also turned off the color channel.
    The omni lights now appear to only light the water material and not the clip…
    is this whats meant to happen??
    Greg
