Activity › Forums › Adobe After Effects › Help with keying
Help with keying
Posted by Chap on October 14, 2005 at 5:55 am
Hi I’m not sure what is the best way of doing this.
I have a clip of a man shot against a dark background and the man is somewhat tinted with a bit of blue. Anyone has any idea which is the best way of keying away the background?
thanks
chapMidicon replied 20 years, 11 months ago 3 Members · 4 Replies -
Midicon
October 15, 2005 at 12:15 amyou can use a ton of stuff… it kinda depends on what your shooting& working with… color key is good if its a solid color… or luma key is good if your droping out a black or white color… iner/ outer key if you want to take your time and get a good key…keylight if its blue/green screen… this list keeps going …
Chap
October 15, 2005 at 10:33 amwell the problem is that the producer decided the results of keying out a blue screen is not as good anyway and so shot the talent against a very dark unlit blueish background and the talent is equally not well lit and worse of all have a blue cast over it. So i’ve tried using a variety of keys, but still not good. I’m only inches away from rotoscoping… help!
Steve Roberts
October 15, 2005 at 3:12 pmStart by rotoing a rough shape around the person, keyframing the shape every now and then. If that doesn’t work, you have to roto right at the edge of the person. Bad news.
Midicon
October 15, 2005 at 4:10 pmi would try the inner/ outer key… i have gotten some great keys with it…i don’t know what that blue cast is your talking about is it spillage that your talking about? if it is try a spill supress tool… but that might be a tough one if its badly lit… and did they film the sublect too close to the BG…
