Activity Forums Apple Final Cut Pro Legacy Help with image
  • Help with image
    Posted by Greg Ball on November 28, 2007 at 6:53 pm
    I bought an video image from istock video. It’s a white door on a gray background that zooms forward and eventually zooms into the keyhole in the door. My problem is that it’s imported as a quicktime file and I’d like to remove all the gray around the door so I can have this door zoom forward to through the key hole with a black background.
    What’s the best way of accomplishing this? Is there a key I can use? A filter? Do I need to crop out the gray and build keyframes? What’s the best method and how would I do this? Thanks
    Brigitta Boccoli replied 18 years, 10 months ago 3 Members · 2 Replies
  • Tvmaninc
    November 28, 2007 at 6:58 pm
    I find rotoscoping that sort of thing in Motion works best. Use the mask tool and animate it. Since the door has straight lines it should be an easy one.
  • Brigitta Boccoli
    November 28, 2007 at 7:31 pm
    You can key the gray directly in final cut, using a chroma key filter. You might experience problems if the same gray is present in other elements of the scene…
