Activity Forums Adobe After Effects help with high res footage
  • help with high res footage
    Posted by Emiliano Ferrara on May 18, 2008 at 5:21 pm
    Hello everyone.
    i have a 25 second sd composition in wich i used some .psd file at 4208*2360 pixel.
    When i rendered out it takes about 12 hours!!!
    Obviously also in ram preview it takes a very long time!!!
    I try to precomposed all the .psd file but nothing changed.
    Someone can help me?
    sorry for my imperfect english i’m from italy.
    tnx in advance.
    emiliano
    Emiliano Ferrara replied 18 years, 4 months ago 2 Members · 6 Replies
  • Simon Bonner
    May 18, 2008 at 5:58 pm
    So your final comp, the one that you rendered, is 4208×2360? If so, your problem is that your comp is just very big. Each frame has 9,930,880 pixels. Compare that to NTSC DVD footage: 720×480 = 345,600 pixels. A quick bit of maths would suggest that if your comp was smaller it would render out almost 29 times faster, in about 41 minutes, which sounds a bit more realistic. Is there any particular reason why you need such a huge video? If there is, you may have to live with the render time.
    Simon Bonner
    youtube.com/simonsaysFX
  • Emiliano Ferrara
    May 18, 2008 at 6:01 pm
    tnx Simon for the answer.
    no my rendered comp is pal 720*576 but inside this comp there are some footage that are 4208×2360.
  • Simon Bonner
    May 18, 2008 at 6:04 pm
    Do you have a render heavy effect (e.g. CC force motion blur, fractal noise) applied to footage at that high res? You may have to provide more info on the setup of your comps.
    Simon Bonner
  • Emiliano Ferrara
    May 18, 2008 at 6:08 pm
    no effects, just a camera that fly trough the high res footage and motion blur enabled.
    but also if i try to turn off the motion blur the render time rest impossible.
  • Simon Bonner
    May 18, 2008 at 6:13 pm
    It sounds like it could be a high demand render. Apologies that I can’t be any more help. It seems like it might just be a case for an overnight render…
    Simon Bonner
  • Emiliano Ferrara
    May 18, 2008 at 7:50 pm
    it’ok….thanks simon.
