Activity › Forums › Apple Final Cut Pro Legacy › Help with HD 16:9 footage into an SD system
  • Help with HD 16:9 footage into an SD system
    Posted by Dan Riley on August 17, 2007 at 7:45 pm
    We have not changed over to HD yet. Still have Uncompressed SD set up with
    DigiBeta etc. Aurora Pipe Studio with SDI in/out and analog monitoring.
    Client is shooting with HDX900, 720p 30. I’m renting a Panny 1400 deck and
    downconverting to SD to input to FCP. While doing that, I’m assuming (here’s
    where I usually get into trouble) I have to choose between letterboxing the
    footage or center cropping the footage while doing the downconvert.
    This means I would work with the HD to SD downconverted clips in a normal
    SD sequence and monitor the same way I do now.
    Yes or no so far?
    Or, does the 1400 deck and FCP allow me to downconvert the HD to SD
    BUT KEEP the anamorphic picture (now at SD) and then put THAT in a
    16:9 SD sequence?
    Dan Riley replied 19 years, 1 month ago 2 Members · 2 Replies
  • Gary Adcock
    August 17, 2007 at 8:04 pm
    the 1400 deck will allow you to do any of 3 things on down converts over SDI
    the menu is 620
    0000 is center cut
    0001 is letterbox
    0002 anamorphic squeeze.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Dan Riley
    August 17, 2007 at 11:01 pm
    Thanks.
    Dan
