Activity Forums Apple Final Cut Pro Legacy Help with frame export
  • Help with frame export
    Posted by Ken Nicholson on July 17, 2008 at 10:45 pm
    I’m having trouble maintaining aspect ratio on some still frame exports. The project (and sequence) is DVCPRO HD (960×720, 59.94).
    At the beginning of this, my first FCP job, I had to export some reference frames. They exported just fine, using Quicktime Conversion jpegs. Now I have to re-export the same frames (340 of them) with the color correction that has been added. I’ve tried just about every sequence setting I can think of and the frames are coming out as 4:3 (960×720). I’ve tried changing the frame size in the Sequence setting menu, the Pixel Aspect setting, even the compressor and the Anamorphic button. Anamorphic gives me a frame size of 1280×720 but the image inside is still 960×720, even when I use 1280×720 frame size or Pixel Aspect. I’ve tried all still image formats. And what’s got me is that if I export a one-frame Quicktime movie, it comes out just fine. What up anyone?
    Ken Nicholson
    Ken Nicholson replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
