Activity Forums Adobe InDesign Help with exporting to PDF
  • Help with exporting to PDF
    Posted by Lukic He on July 10, 2008 at 7:14 am
    I need some help. I have problems exporting my indesign file tot PDF. The next problems occur.
    1. Text gets randomly bold when I go printing (I get slightly better results with another printer). Textype is Myriad pro.
    2. Some pages have a stroked box around them, others have not (as it should be).
    3. On a page with a grey background and a fex pictures on them I get two random boxes with darker gray.
    I want PDF to export just what I see in Indesign. Why is something that should be so easy, so difficult. I am working for days to fix all this. Trief numerous different PDF export settings (unemebdded the fonts, etc.).
    Please help!
    Mike Moqu replied 17 years, 11 months ago 3 Members · 2 Replies
  • Tim Cole
    July 10, 2008 at 10:12 pm
    Does this file have transparency? What version of PDF are you saving to? Where do the stroked boxes appear? In print, on screen?
  • Mike Moqu
    October 2, 2008 at 4:24 am
    1. make sure you have Postscript fonts.
    2. check you embed the fonts
    3. check flattening and transparency settings on the objects that do not work as expected – you do not want RGB and CMYK objects to overlap or be used in the same document (use CMYK) – drop shadow requires high resolution flattening to be applied.
    4. export as eps and distill in distiller – best way to ensure everything will work.
    fast export with InExport free from apple downloads page (Apple only), try java script from the java dev website – they offer a wide range of scripts (if you are familiar with java).
    cheers
    mike m
