Activity Forums Apple Motion Help with emitters/replicators
  • Help with emitters/replicators
    Posted by Riccardo Riva on April 7, 2022 at 6:41 am
    Hello everybody!
    Sorry for the maybe newbie. question but I can’t figure out how to do this!
    I basically want to replicate this effect where there are these wheat things that go from the shape the hand is following and end up on the gauge. I was thinking about using a replicator and moving the starting point but with no luck.
    Any suggestion?
    Riccardo Riva replied 4 years, 4 months ago 2 Members · 2 Replies
  • Robin S. kurz
    April 7, 2022 at 9:09 am
    You’ll want to use a Particle Emitter attached to a path along with the hand. Emit from a point and maybe try playing around with an Attractor behavior on a random object to “suck” whatever your particle is to where you want them to go.
  • Riccardo Riva
    April 7, 2022 at 9:16 am
    Thank you! I linked the hand movement to the emitter but didn’t know about the attractor behaviour! Thank you so much!
