Activity Forums Avid Media Composer Help with DVD
  • Help with DVD
    Posted by Robert Mcgowan on March 6, 2007 at 12:15 pm
    Hi
    I use Sorenson Squeeze to covert my QT Ref files to MPEG2
    However I have noticed that the top 3-5 pixels show a green line during composited parts (i.e titles and picture in picture effects) of the sequence.
    This is in the area of overscan that you would not normally see on conventional TV or a monitor, however it is noticeable when viewing the MPEG2 footage on the computer as the full frame size is seen.
    How can I avoid this without having to crop the top 3- 5 pixels off the top of the frame?
    Has anybody any idea what I am talking about?
    robert.
    Robert Mcgowan replied 19 years, 5 months ago 2 Members · 4 Replies
  • Joe Womble
    March 6, 2007 at 4:51 pm
    What version of Squeeze and which Avid product/version are you using?
    Regards,
    Joe Womble
  • Robert Mcgowan
    March 6, 2007 at 11:52 pm
    I use Squeeze version 3.53.300
    and Avid Xpress Pro HD ver. 5.2.1
    the strange thing is that only the top 3 – 5 lines of pixels only appear as green when played at full frame.
    its an odd one can’t work out why, its obviously seeing the data on the quicktime reference file which isn’t obvious when I play the timeline in avid, but I am guessing it must be there, but only when an effect is applied, its as though there is a matte of green in the background but the video hasn’t sufficant height to cover those 3 – 5 lines. Actually it is visible when I select overscan on my monitor.
  • Joe Womble
    March 7, 2007 at 5:56 am
    There was some discussion a while back about this on the Avid Community Xpress Pro Studio User Forums.
    https://www.avid.com/exchange/forums/45/ShowForum.aspx
    Do a search for “Avid DVD green line” and see if that matches what you are experiencing. I think it may have been associated with your version of Squeeze (there have been updates to this program since) and the version of QuickTime you might have.
    I’m running the lastest versions of Squeeze and AXP, and I don’t see the green lines on my material.
    Regards,
    Joe Womble
  • Robert Mcgowan
    March 7, 2007 at 9:02 pm
    Thanks for the tip Joe – have read into your pointer and have found a solution – if anybody else needs it please drop me a line or see the thread for the right direction to go.
    Robert.
