Activity Forums Adobe After Effects Help with creating video montage
  • Walter Soyka
    October 18, 2020 at 2:24 am
    You’ll need to make each of the clips the exact same length, then lay them all out in a sequence in a precomp. Make the precomp the exact duration of the sequence.
    Place that precomp somewhere in the comp where you have Particular. Use a Sprite or Textured Polygon as your particle type, choose your precomp layer as the Texture Source, and set its Time Sampling to “Split Clip – Play Once.” You will also need to set the exact number of clips.
    There’s more in the docs here:
    https://www.redgiant.com/user-guide/trapcode-particular/particle-texture-group/
