Activity › Forums › Apple Final Cut Pro Legacy › Help with client monitor
  • Help with client monitor
    Posted by Larry Sherwood on November 13, 2007 at 7:27 pm
    I need to have a 48-50″ Plasma or LCD for clients to view. The projects will always be 23.98 or 24 frame. Does anyone have real-life experience with any plasma or LCD’s that actually support 23.98 or 24 fps via HD-SDI or Component HD? It must be a 50″ monitor . . .video will come from an AJA BOB or AVID DNA DNXcel board
    Thanx for any and all advice
    LS
    Walter Biscardi replied 18 years, 10 months ago 5 Members · 6 Replies
  • Chris Borjis
    November 13, 2007 at 8:19 pm
    Panasonic Industrial Series of Plasmas should do just fine.
    look into the 50UK model.
  • Chris Borjis
    November 13, 2007 at 8:20 pm
    that should have read 50 inch 10UK model.
  • Eric Grush
    November 13, 2007 at 9:00 pm
    Yes…I got a Panasonic 42″ 9UK from the same series for under $1000 and use it for client viewing and paired with a Sony CRT for color correction. The image is extremely clean and matches the CRT very well. It also runs component from my KONA 3 at a wide range of sizes and frame rates.
    Best of luck.
  • Aaron Neitz
    November 13, 2007 at 9:50 pm
    And they have an HD-SDI plug in board for the Panasonics. Works great. 23.98, 24.0, etc…. the set looks nice with SD images too.
  • Larry Sherwood
    November 13, 2007 at 11:42 pm
    Thanks to all, just put in my order for the TH-50PF9UK with the optional HD-SDI board. It does seem to be the most sensible option . . .today
    Thanx again,
    LS
  • Walter Biscardi
    November 13, 2007 at 11:44 pm
    [Larry Sherwood] ”
    Thanks to all, just put in my order for the TH-50PF9UK with the optional HD-SDI board. It does seem to be the most sensible option . . .today”
    Just FYI, we run two Panasonic plasmas and we run them via Component. Didn’t bother with the HD-SDI and they look fantastic. Just an FYI if you want to save some money.
    I did pick up the HDMI input for our BluRay player though.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
