Activity Forums Panasonic Cameras help with capturing Firestore FS-100 into Avid Express Pro
  • help with capturing Firestore FS-100 into Avid Express Pro
    Posted by Steve Voyk on April 6, 2007 at 4:18 pm
    Hi guys,
    I have posted this on the Firestore forum but no help as yet, so was hoping someone here might know.
    I’ve just started to do some tests with the FS-100 and my HVX202 (PAL). I managed to get the FS-100 unit to record correctly with about 10 test clips in DVCPro (25)format with “OMF” as the REC setting (for Avid ingest).
    I did an “organize OMF”, then connected the FS-100 to the Avid Xpress Pro (version 5.0), and switched the FS-100 to “DD”. My PC shows the 10 folders which I assume are the clips, but there is nothing inside each one. There is another folder with a long number as the name which has a few Gb’s in it so I assume that is the issue perhaps?
    I’m unsure what to do when importing on the Avid side … I have created the correct project, new bin and tried importing with the DV25 420 setting, but it returns an error if I try importing any of the clips in that large folder that had a few Gb’s inside it. I am not that experienced on the Avid having come from another high-end NLE system.
    Can someone give me some steps as to what I should be doing to import simple SD material into my Avid Express Pro please, or is it an Organize OMF issue on the FS-100? In addition, should I be importing directly off the FS-100 or can I transfer the files to another hard drive before hand, then import from there? If that’s the case, what folders/files do I transfer across exactly?
    Many thanks,
    Steve
    Perth, Australia
    Accountneedsrealnameupdate replied 19 years, 4 months ago 2 Members · 3 Replies
  • Accountneedsrealnameupdate
    April 6, 2007 at 5:05 pm
    I have only used the FS-100’s in HD MXF, and have never tried using OMF files, but I’m guessing the process is the same. It sounds like you are trying to import them, when you need to just directly read them. Connect the FS and put it into DD as you’ve been doing, but open the media tool, (from the ‘tools’ menu), in avid and point to it’s drive letter. Your clips should show up in the media tool. Now you can consolidate them and drag them to a new bin. (if you’re new to Avid, consolidate is Avids way of copying clips to your main media drive).
    Hope this helps.
  • Steve Voyk
    April 8, 2007 at 1:21 pm
    Hi “Rumpy”…
    Many thanks for the info… yes, it really helped. I got the Express Pro system to import the files without any issue.
    If you have time, can you explain why Avid uses a ‘media tool’ rather than going straight to a normal BIN with these kind of files. I can’t work out the difference between the two…
    Regards and thanks again,
    Steve
    April 8, 2007 at 9:38 pm
    Hi Steve,
    I cannot really claim to be an expert here, so hopefully someone else will jump in if I’ve got this wrong, but I believe the issue here is more semantics than anything else. My understanding is that ‘import’ is Avid speak for convert. If you have an mpeg or QuickTime movie or whatever, you ‘import’ it, which converts it into native Avid files, (MXF or OMF), just like the capture tool does with tape. If your files are already native Avid, they do not need to be ‘imported’, (converted), you just need to point Avid at them. Panasonic P2 files are native Avid MXF format, and are treated just like an Avid media drive. The Avid media tool pre-dates P2 by like a million years or something, and can be used for moving media files between two Avids, i.e. you can ‘consolidate’, (again, Avid speak for copy), the contents of a bin to an external drive, then take it to another Avid and use the Media tool to read it. You can also use the media tool to directly read a P2 card in a PCMCIA slot or even in the camera via the firewire or USB cable, and then edit directly from there without ever copying anything to the Avid media drive. I’ve never had the need, but it saves the ENG guys a lot of time to do it that way.
    One thing I find a little annoying about the process is that the ‘Contents’ folder of the P2 card must be in the root of the drive directory. This means if you are out shooting on P2 cards and want to copy them to another drive, like a portable hooked to a laptop, you cannot make separate folders for each card because the media tool will not see them. This is why the P2 Store makes different drive partitions each time you copy a card. I really wish Avid would allow you to browse a normal file structure instead of just pointing at the drive but I’m guessing it might have to do with Mac compatibility. not sure.
    I’ll spare you all of my opinions of the Firestore drives, (fortunately I’ve taken my turrets medicine), but I will tell you the way I prefer to use them in the field. If I’m doing fairly short gun and run takes, I shoot to the P2 cards, then set the camera to 1394 host, put the FS-100 in DD mode, and copy the files in between takes. This method is kind of a waste of an FS-100 because it’s really just acting as an over priced battery powered firewire drive, but I have lost WAY too many shots to flakey firewire cables. I still use them as intended when the camera’s on sticks or any time I need a long continuous shot, like a seated interview, but the little four-pin firewire connector on the camera is just a raging disaster waiting to happen. Even on a tripod you really need to tape down the cables and be really careful when panning, and always keep your eye on the red recording dot in the viewfinder. If the cable jiggles during a shot, the FS-100 just quietly stops recording. If you’re foolish enough to be watching your talent/action instead of your gear, you can easily end up with half a shot. But that’s enough ranting for now. My kingdom for a Cineporter!!
    Hope this helps.
