Activity › Forums › DVD Authoring › help with av sync
  • help with av sync
    Posted by Jack Laurie on July 21, 2007 at 6:21 am
    if Im in the wrong forum please ‘politely’ tell me where to go.
    This is kind of a reverse question but, I simply want to rip several 3-10 min seg from a dvd vob file. I used virtualdubmob and got what I want but the sound is subtly off. I farted around with the msec adjust time thing but can’t easily solve it. I think its when it first pullit in and interleaves the mpeg (think thats what it says its doing?)
    What is the easiest way to get perfectly synced avi files from a vob file. I was usiing the 3xiv codec save to avi,but I think that’s not where the problem is.
    thanks for any advise.
    Jack
    Dan Asselin replied 19 years, 2 months ago 2 Members · 1 Reply
  • Dan Asselin
    July 31, 2007 at 1:06 am
    Hi: This is a post I sent to some others but it might be of interest to you as well. In order to help you with synch I would simply skip the step using FILE MERGER and work with the pieces.
    I remember the first time a client gave me a dvd to get my content from. I thought I was in real trouble. Then I went to the web and found that everything I needed was available for free.
    First I use a program called DVD SHRINK to pull my assets from the disk. Then I use a small program called file merger to place the VOB files together, in order, and then finally a program called REJig (in file mode) to de-multiplex the vob files into M2V and AC3 streams which can be imported any authoring programs.
    I assure you it is not as complicated as it sounds. Here are some links that may be of assistance to you.
    https://www.videohelp.com/
    https://www.dvd-guides.com/
    Good Luck
    Dan
