Activity Forums Adobe After Effects Expressions Help with Applying Expressions to Different Type of Layers
  • Help with Applying Expressions to Different Type of Layers
    Posted by Vincenzo Imbimbo on February 21, 2025 at 2:25 pm
    Hello everyone,
    I’m working on a script for After Effects where I apply expressions to properties of the Transform effect (not the layer’s direct transform properties).
    I’m trying to apply expressions to properties of the Transform effect (transformAnchorPoint and transformPosition), but it seems the expressions are not being applied. The effect is applied to the layers, but no expression is assigned to these properties.
    try { var transformAnchorPoint = transformEffect.property("ADBE Geometry2-0001");
    var transformPosition = transformEffect.property("ADBE Geometry2-0002");
    // Check if the layer is a Shape Layer or Text Layer
    if (thisLayer instanceof ShapeLayer || thisLayer instanceof TextLayer) {
    transformAnchorPoint.expression = "my expression;";
    // Condition for button 5
    if (direction === "5") {
    transformPosition.expression = "my expression;";
    } else {
    } else {
    // For solid or image layers (JPG, PNG, AI, PSD, etc.)
    } else {
    } catch (e) {
    continue; // If an error occurs while adding expressions, continue to the next layer
    Vincenzo Imbimbo replied 1 year, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 21, 2025 at 5:31 pm
    I’m not sure what the issue is–I just ran a little test, and this worked for me:
    var transformEffect = app.project.activeItem.layer(1).property("ADBE Effect Parade").property("ADBE Geometry2");
    transformEffect.property("ADBE Geometry2-0002").expression = "value";
  • Vincenzo Imbimbo
    February 21, 2025 at 6:07 pm
    Thanks Dan, i found the solution by doing it this way:
    try {
    // Detect type of layer
    var isShapeLayer = layer.matchName === "ADBE Vector Layer";
    var isTextLayer = layer.matchName === "ADBE Text Layer";
    if (isShapeLayer || isTextLayer) {
