Activity › Forums › Avid Media Composer › Help with an audio effect
Posted by Joe Biscotti on December 28, 2006 at 2:42 amI need to speed up audio to match a video motion effect. I want to keep sync with the motion effect. WHat do I hvae to do. The Video motion effect is at 1760fps. System is compaq xw8000 running XPro 4.6
Don Logan replied 19 years, 9 months ago 4 Members · 6 Replies -
Michael Phillips
December 28, 2006 at 2:47 pmWow… if working at 30fps that is a 58x faster. I don’t know if the audiosuite plug-in has a 5800% speed up. You may have to do that in steps – render, export as WAV, bring it back in, apply audiosuite and render again till you get to the right percentage.
anything 24fps
Joe Womble
December 28, 2006 at 3:39 pmI would think you could “fake it” by using whatever speed the audio effect would allow (300 percent? 500 percent?).
It would probably appear correct to the viewer without being mathmatically correct.
Regards,
Joe Womble
Michael Phillips
December 28, 2006 at 5:12 pmOK Joe… I see what kind of student you were in school… 😉
anything 24fps
Joe Womble
December 28, 2006 at 5:30 pmAudio? We don’t care about the audio!!! 😉
Seriously, I would think that 5800% audio would sound like hash. If it was sped up 300% or 500% it might be somewhat intelligible. All this is conjecture not knowing the audio source…
Regards,
Joe Womble
Michael Phillips
December 28, 2006 at 8:26 pmI agree, at that rate you could use audio from anything and it would stll work –
Michael
anything 24fps
Don Logan
December 28, 2006 at 10:01 pmWhen you say that you want it to match the motion effect do you mean you want to keep it in sync with video? what type of effect are you doing with what kind of audio. a talking head etc.. There are a couple of tricks in Audio suite that sound like they might work. Let us know, thanks.
