Activity Forums Adobe After Effects help with after efffects exporting settings!!
  • help with after efffects exporting settings!!
    Posted by Pigglet In the city on September 24, 2005 at 4:11 pm
    I am using after effects 6.5 porofessional, and I need to export a movie with these settings, which I cannot find anywhere.
    1920×1080 29.97fps uncompressed 10bit 4:2:2 square pixels, upper field dominance……
    I have been able to find the 1920×1080 29.97fps uncompressed
    but have no idea where to set it to 10bit 4:2:2 square pixels, upper field dominance……
    Please help me!!
    Thx
    M.
    Pigglet In the city replied 21 years ago 3 Members · 13 Replies
  • 13 Replies
  • Peter O’connell
    September 24, 2005 at 6:02 pm
    You need to download the blackmagic quicktime codec I think.
    Pete
  • Pigglet In the city
    September 24, 2005 at 6:23 pm
    and then….?
    September 24, 2005 at 6:40 pm
    YAY! I figured it out! thanks sooo much!!
    September 26, 2005 at 3:39 am
    why is it that when I export using uncompressed 10 bit 4:2:2 the alpha channel no longer exports and the RGB + Alpha option goes away?
    How do I fix this problem?
  • Steve Roberts
    September 26, 2005 at 4:15 am
    Not all codecs support an alpha channel. For these codecs, you should create two 10-bpc (bits per channel) output modules: for an RGB video, and an alpha video. Then you bring both rendered videos into your editing app and use the alpha movie as a luma matte for the RGB movie.
    If you want 16-bpc quality and an alpha channel, check out Microcosm.
    Otherwise, render to Animation — it’s an RGBA codec, but only 8bpc.
    Does that help?
    Steve
    September 26, 2005 at 2:27 pm
    thanks so much!
    so i guess i need to render 2 movies and let the editor put them together?
  • Steve Roberts
    September 26, 2005 at 3:10 pm
    Yep!
    Tell the editor first. Some rarely use luma mattes. 🙂
    September 26, 2005 at 3:24 pm
    will try this. thanks!!
    September 26, 2005 at 4:41 pm
    does anyone know if is there an uncompressed 10 bit 4:2:2 codec with alpha out there?
