Activity › Forums › Adobe After Effects Expressions › Help with a script TONIGHT PLEASE
  • Help with a script TONIGHT PLEASE
    Posted by Adam Forbes on November 12, 2009 at 6:58 am
    I need some help fast.
    I have multiple projects and thousands of layers so I need a script that will add this expression to every anchor point and every position of a layer:
    tempx = value[0];
    tempy = value[1];
    tempxwhole = Math.round(tempx);
    tempywhole = Math.round(tempy);
    [tempxwhole, tempywhole]
    It’s a simple expression to round the position to the nearest integer which in turn makes the illustrator file appear more clear.
    What I need is a script that will apply that expression to all layers selected:
    I NEED it ASAP!
    tempx = value[0];
    tempy = value[1];
    Dan Ebberts
    replied 16 years, 10 months ago
    2 Members · 5 Replies
  • Dan Ebberts
    November 12, 2009 at 4:15 pm
    Try this:
    var expr = ‘tempx = value[0];\r’ +
    ‘tempy = value[1];\r’ +
    ‘tempxwhole = Math.round(tempx);\r’ +
    ‘tempywhole = Math.round(tempy);\r’ +
    ‘[tempxwhole, tempywhole]’;
    var myComp = app.project.activeItem;
    var myLayer;
    for (var i = 1; i <= myComp.numLayers; i++){ myLayer = myComp.layer(i); try{ myLayer.property("anchorPoint").expression = expr; }catch (err){ } myLayer.property("position").expression = expr; } } Dan
  • Adam Forbes
    November 12, 2009 at 4:28 pm
    Dan,
    That’s awesome thanks so much. It doesn’t seem to work for the WHOLE PROJECT. Is there a way to get it to go through every comp in the project instead of just the one I’m in?
    Adam
  • Dan Ebberts
    November 12, 2009 at 5:39 pm
    var myComp;
    var myLayer;
    for (var j = 1; j <= app.project.numItems; j ++){ myComp = app.project.item(j); if (myComp instanceof CompItem){ for (var i = 1; i <= myComp.numLayers; i++){ myLayer = myComp.layer(i); try{ myLayer.property("anchorPoint").expression = expr; }catch (err){ } myLayer.property("position").expression = expr; } } } } Dan
  • Adam Forbes
    November 13, 2009 at 11:27 am
    Dan,
    That worked great for a while, then it seems to really get tripped up by hidden layers.
    It says Unable to execute scrpt at line 19. After Effects error. Can not “set Expression” with this property, because the proptery or a parent property is hidden.
    any ideas?
    Adam
  • Dan Ebberts
    November 13, 2009 at 5:40 pm
    That’s strange. See if this helps:
    var myComp;
    var myLayer;
    var isHidden;
    var isLocked;
    for (var j = 1; j <= app.project.numItems; j ++){ myComp = app.project.item(j); if (myComp instanceof CompItem){ for (var i = 1; i <= myComp.numLayers; i++){ myLayer = myComp.layer(i); isLocked = myLayer.locked; myLayer.locked = false; isHidden = myLayer.hidden; myLayer.hidden = false; try{ myLayer.property("anchorPoint").expression = expr; }catch (err){ } myLayer.property("position").expression = expr; myLayer.locked = isLocked; myLayer.hidden = isHidden; } } } } Dan
