Activity Forums Adobe Premiere Pro Help with 3 and a 1/2 hour project
  • Help with 3 and a 1/2 hour project
    Posted by Joe Cinquina on March 21, 2006 at 9:42 pm
    I just completed editing a 3 and 1/2 hour play. After I add an intro sequence, credits, some interviews, motion menus it will probably be around 3 and 3/4 hours. My question is; how do I author this? I have a dual layer dvd burner, but if I want to maintain the best quality video, I can not fit it on one. Is there some setting that will make it all fit and wont sacrifice “noticeable” quality? If I have to go to (2) DL DVDs and the jackets, I will see very little profit. Any help would be appreciated. Thanks in advance.
    Regards,
    Joe Cinquina
    Hector Melendez replied 20 years, 6 months ago 4 Members · 5 Replies
  • Mark Weaver
    March 21, 2006 at 10:04 pm
    Joe,
    I just finished a project with 5.5 hours of video
    that I split across 3 DVD-Rs. If you use two DVD-Rs
    you should be able to get acceptable quality and
    4 hours of video. Since DVD-R is lower in cost than
    DVD-R DL this might help you out with finances.
    Just my 2cents.
    Mark
  • Joe Cinquina
    March 21, 2006 at 10:08 pm
    Mark _ Thanks. Did you encode this in Premiere or Encore? What settings did you use? What did you give up as far as quality? Does black look really black or is it grainey? Thanks again.
    Regards,
    Joe
  • Mark Weaver
    March 21, 2006 at 11:11 pm
    Joe,
    For the most part I use Premier Pro to do the
    encoding. If you break the video up into two pieces
    you should be able to get a target bit rate of
    4.5Mbits/s. Then just play with the lower bit rate
    and highest bit rate. Making the highest bit rate
    less than 7Mbit/s has worked okay for me in these
    types of projects but then again the quality was just
    DV to begin with.
    Also, if there isn’t a lot of fast movement(camera
    or object) you can set the quality to 3-3.5 and
    the MPEG encoding will move alot faster than at 4-5.
    Hope this works for you.
    Mark
  • Mike Cohen
    March 21, 2006 at 11:30 pm
    For hoo-ha’s why don’t you set the bit rate low enough to fit the whole thing on one disc. It may come out horrible, but would be an interesting experiment.
    Also, if this is a school or community play, it may still look better than the usual VHS tapes people are accustomed to seeing.
    I did a DVD last year with over 3 hours on a single layer DVD-R – did not look horrible, although it was mostly talking heads and static slides.
  • Hector Melendez
    March 22, 2006 at 8:37 pm
    I will like to see how this is achievable and the final quality with a footage so longer.
    I never do DVD’s longer than 2 hrs and only one time did a 2:40 hrs but pixelitation was noticiable…
    I know the final quality depends upon the quality of the footage feeded
    but, please, any of you can show the way… could be 3hrs? by Encore, or how?
