Activity Forums Adobe After Effects Help with 2d motion, the stroke is changing as it moves around
  • Help with 2d motion, the stroke is changing as it moves around
    Posted by Tainara Cardoso on September 6, 2024 at 1:21 am
    Hi everyone!
    I’m experiencing a strange issue while working on a 2D motion in After Effects. It feels like there’s an invisible 3D axis where, as objects move closer to the center of the screen, they seem to recede in depth (as you can see in the videos attached). This affects the stroke of my lines, making them thinner as they approach the center of the screen and thicker as they move away. Has anyone else encountered something like this, or does anyone know if this could be due to an effect or expression that might be causing it? I’m trying to keep the stroke thickness uniform.
    Any help would be much appreciated!
    John Cuevas replied 2 years ago 2 Members · 1 Reply
  • John Cuevas
    September 6, 2024 at 2:18 pm
    Can you upload the project files where that is happening? It’s hard to speculate based on the screen capture.
