Activity Forums Avid Media Composer Help- which FCP compressed codec to read in avid session?
  • Help- which FCP compressed codec to read in avid session?
    Posted by Richard Dee on May 5, 2006 at 3:41 am
    I have to send some 720x 486 QT mov’s from FCP over the web for an output to tape on an avid, and I’d like to avoid having
    to upload uncompressed 8 or 10 bit files. I’ve had great luck with the pixlet codec (at almost 10:1 compresion)
    – but more than likely this won’t be able to be read by the avid.
    so- what compresed codec should I use from FCP that will be able to read on an avid- I’m not sure
    what version or even if it’s on mac or PC- it’;s just an output to tape but is being done across
    in another city.
    thanks
    John Pale replied 20 years, 4 months ago 3 Members · 2 Replies
  • Wes Plate
    May 5, 2006 at 4:06 am
    Any Quicktime codec will do. Unless you render to the Avid codec the Avid will recompress the movie during import anyway.
    — Wes Plate
    Automatic Duck
  • John Pale
    May 6, 2006 at 11:19 pm
    Best to use the Avid Quicktime Compressed codec. You will probably find 2:1 or 3:1 compressed will retain decent picture quality and have reduced file size over uncompressed
    download from here..
    https://www.avid.com/onlinesupport/supportcontent.asp?productID=0&contentID=3555&typeID=
    For best results, export a reference movie from FCP in the codec you edited in, then use Quicktime Pro or Compressor to convert. The Avid Codec can be a bit unstable within FCP, but works fine elsewhere.
