Activity Forums Adobe Photoshop HELP! weird staircase artifacting on image when used in flash
  • HELP! weird staircase artifacting on image when used in flash
    Posted by Louis Sparre on August 22, 2007 at 8:31 pm
    hey all.
    I’m trying to use our company logo in flash. The problem I’m having is that the image contains a few diagonal lines that are so sharp that they wind up looking like staircases instead of smooth lines.
    does anyone have a solution for this?
    Thanks in advance.
    Abraham Chaffin replied 19 years ago 2 Members · 1 Reply
  • Abraham Chaffin
    August 28, 2007 at 8:51 pm
    I assume this is a transparent gif image – correct me if I’m wrong.
    A lot of times when you use transparent gifs you get the weird staircase thing because of the way the program is interpreting the transparency pixels. It makes each pixel either 100% on or 100% off rather than feathering the pixel transparency. For instance if you had a black pixel on a white background with 50% transparency it would be grey but since the program doesn’t do 50% transparency it will be black and 100% opaque.
    Solution is either make your image a flat jpg with the background color you are wanting, create the logo in flash, or create the logo as a psd and import it into flash. There may be other ways but these are a few.
    Abraham
