Activity Forums Apple Final Cut Pro Legacy HELP! Weird FCP Launch Problem!
  • HELP! Weird FCP Launch Problem!
    Posted by Tony Brittan on March 27, 2009 at 3:24 pm
    OK…I’ve never seen this before and I can’t find anything on the forums for it so here it goes: Yesterday I did some cleaning up of my hard drive to get ready to start editing on a TV program I do. I thought I’d done everything correctly but maybe not. After archiving my projects as self-contained QT’s and putting them on an external drive, I went through and deleted all that I didn’t need on the drive anymore.
    Now, when I launch FCP…wether it’s from the dock, the app folder or opening a previous project, it comes up with this warning:
    The movie file “Lines-FIN-00000002” cannot be found. Without this file, the movie cannot play properly.
    Then it makes me search for it a couple of times before moving on. It’s really bugging me! I know what project that’s from and I still have the project on the system. I didn’t actually end up using that clip but had in the past. I’ve tried everything to make it forget that file but it looks for it every time it launches now!!! What can I do? I’ve repaired permissions a couple times, restarted, opened the project and tried to make sure it’s not in use and it’s not…I don’t know what to do!
    I’m using FCP 6.0.4, Octo-core with 4GB ram. Can someone please help a brutha out? Is there a way to re-set what it’s looking for? I hadn’t even opened that project in a while and didn’t do anything with it when I was cleaning up the hard drive.
    Thank you in advance!
    Tony Brittan replied 17 years, 5 months ago 4 Members · 12 Replies
  • 12 Replies
  • Tony Brittan
    March 27, 2009 at 3:32 pm
    I just tried to re-open the project that this is from and now it’s also looking for the same thing but with a “1” at the end. They are 2 files I didn’t actually use in the project and the original clips have since been removed from the project. What gives?
  • Steve Eisen
    March 27, 2009 at 3:57 pm
    FCP is looking for render files. What you thought to be self-contained movies, are actually reference movies.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Tony Brittan
    March 27, 2009 at 4:15 pm
    Actually, the files that I moved around had nothing to do with this particular file. I just got off the phone with Apple support and when we change my scratch disk to another location, it opens fine. I never even touched the scratch folders for this particular file! She told me that I would have to re-aquire that footage and recreate it then, delete if if I want it to stop, or use a new scratch folder.
    Isn’t there a way to tell FCP not to look for that render file? Weirdest thing is that even if I’m not dealing with that project at all, it’s still looking for it. Even if I close all projects, close FCP and reopen it to an untitled project, it still looks for it!
    Any ideas?
  • Tony Brittan
    March 27, 2009 at 4:42 pm
    OK…assuming this is the case, and I don’t have a matching file, how can I make FCP forget about this render file? I’ve tried re-creating the files, putting them into a timeline and rendering them to force a render file with this name and that didn’t work. I found a render file with the same name but a “3” instead of a “2” at the end so I’ve copied it to my desktop, renamed it to the name of the file that it’s looking for, and when it asks me to search for it, it will find the file (the only one not greyed out), I select it and it moves on. When it actually opens the program, it does it again. I saved it, closed FCP and opened it again only to find the exact same thing! I don’t want to have to change my scratch folder but I think that might be the only thing I can do. If I need to open any projects from the old scratch folder it’s going to run me through this again.
    Any ideas?
  • Michael Black fcp
    March 27, 2009 at 4:56 pm
    Not sure how to fix this exactly. Did you trash the prefs and all that?
    In the future, you should use the media manager when doing something like this, so that all the necessary files get copied over and saved.
  • Tony Brittan
    March 27, 2009 at 5:07 pm
    Yea, I did all the usual stuff with trashing prefs and what-not. Changing the scratch disk location works but I have a few projects in the old location that I need to work on from time to time. I use media manager when I want to archive the whole project. For yesterdays purpose, I simply exported native quicktime, self-contained, and saved the finished movie. Then I went in and deleted the folders that contained old projects as well as the actual project files.
    The strange thing here is that the file that’s causing the problem is in a project that I didn’t touch and there were no stray files existing in any other project stuff that I dumped. In fact, these are render files that are in a project that I haven’t messed with in a while at all. And when I go in to the render manager after getting this project to open, it doesn’t have a folder listed for this particular sequence at all. It was called “Lines” and that was taken out of the project months ago.
  • Tony Brittan
    March 27, 2009 at 6:04 pm
    Update…the only thing that works to fix this is to create a new scratch folder on my media drive, change all the scratch settings…including waveform, thumbnail, and autosave vault settings…to the new scratch folder and it all seems to work fine.
    I dunno…maybe there is a corruption in the old scratch folder location or something.
    While I was typing this, I had an idea…I changed the regular scratch folder back to the one it was using, left the Autosave vault in it’s original location (on the system drive in Final Cut Pro Documents) and then changed the waveform cache and thumbnail cache from their original locations (both in the same folder as where the Autosave was at…the default install location on system drive / Final Cut Pro Documents) to the scratch location on my media drive where all the other scratch stuff has been living and it seems to have fixed the problem. Must be something with either the waveform or thumbnail caches!
    Can you clear those caches? Am I going to run into problems with the way I’ve got it set up?
    Either way, maybe this thread can help someone in the future. I rarely post here but scour this forum every day. So far this is my first problem I had to bring to the table but many posts I’ve read in the past have helped me before I ever even get to the problems so thank you all!
    Tony Brittan
    islandshoreproductions.com
  • Tony Brittan
    March 27, 2009 at 6:11 pm
    OK…that is until you try to open the project with the offending file in it! I did that with the new settings and it’s happening all over again.
    Never a dull moment!
  • Dennis Leppell
    March 27, 2009 at 6:17 pm
    delete the waveform and thumbnail folders from your scratch disk, and blast ALL render files with the render manager thru FCP. Empty trash, and you should be done.
    IF it comes back again, click the “forget” checkbox when it tells you the file is missing, and you should be good.
  • Tony Brittan
    March 27, 2009 at 6:19 pm
    I’ve narrowed it down to the Thumbnail Cache. If I delete the info inside that folder, all is well until I open the project with the missing render file in it. If I have to open that project, it will cause the problem again. Maybe I should use Media Manager to create a new project from that once it’s open.
    Thank you all again! You rock.
