Activity › Forums › Avid Media Composer › Help! Web wmv export setting
Posted by Sabrina Xaviar on October 1, 2008 at 1:17 pmI can’t get avid to export a good quality .wmv for the web.
windows media 9
320X240
bit rate 1000
ProgessiveWhat am I doing wrong?
sxaviar
Sabrina Xaviar replied 17 years, 11 months ago 4 Members · 5 Replies -
Grinner Hester
October 1, 2008 at 2:07 pmsend a QT reference to Sorenson and make it there.
1000 bitrate is mooore than enough for the web but Avid doesn’t make an encoder, really.
If it helps, I use 480X360, usually about 500 kbs, and 28k audio.
Sabrina Xaviar
October 1, 2008 at 2:24 pmI have the academic version of media composer and I don’t think it came with sorenson squeeze but I’ll check the box.
sxaviar
Mark
October 1, 2008 at 2:31 pmYou can also download the free windows media encoder from Microsoft…From Avid export an uncompressed AVI file, then use the windows media encoder to create your wmv. The windows media encoder is a great tool that creates fantastic compressions…and it is free !!
Mark
Mark Harvey
Senior Editor
Le Réseau des sports -
David Braswell
October 1, 2008 at 9:07 pmExactly what is wrong with the created file? And what was the acquisition format. I’ve exported plenty of one-pass WMVs from Avid and they look pretty good. Also, what are you using the WMV for? Web? Powerpoint?
Sabrina Xaviar
October 2, 2008 at 1:33 pmThe file looks blurry. I need the wmv file for the web.
sxaviar
