Activity Forums Apple Final Cut Pro Legacy Help w/ basic FCP6 edit suite
  • Help w/ basic FCP6 edit suite
    Posted by Jeremy Sexton on November 10, 2007 at 12:30 pm
    The company I work for is looking to create local/regional ads, not national spots, by way of a FCP6 Apple system. As we hope to expand, what are some basic recommendations for the system we should pursue, to build a solid foundation to grow on. We want to stay with Apple computers, 30″ & 23″ displays, but please feel free to suggest some specs for the comp, and a solid external drive(s) or maybe something else I’m missing to get up & running. I’m sure we will still outsource for some final broadcast needs, but to edit and prduce, where should we start?
    Thank you for any help
    Tom Meegan replied 18 years, 6 months ago 2 Members · 3 Replies
  • Tom Meegan
    November 11, 2007 at 12:31 pm
    What format will you shoot?
    How will you deliver the final product?
    The answers to those two questions will largely determine how much computer and what additional equipment you will need.
    However the short answer is to buy the best you can afford. It will last longer and have fewer issues, not to mention save time everytime you render or encode.
    Best,
    Tom
  • Jeremy Sexton
    November 11, 2007 at 5:55 pm
    Shoot on 35mm and HD, hoping to stay more on the HD side. produce braodcast quality for tv. I hope that helps?
  • Tom Meegan
    November 12, 2007 at 3:08 am
    35mm can be telecined to:
    D5
    HDCam
    Digital Beta
    BetaSP
    DV
    etc. These all have different requirements for capturing.
    HD can be acquired in a variety of flavors that make very different demands on a system:
    HDCam
    DVCPro HD
    HDV
    come to mind. Yet more ways to capture. Each choice effects your needs.
    Also, there are a number of strategies/CODECs for capturing the HD footage:
    Uncompressed
    ProRes
    DVCPro HD
    Native HDV
    Apple Intermediate CODEC
    DV down convert for off-line
    and others.
    You mention that you might outsource the output. This would have a large impact on your needs. Here is some examples:
    Down convert to BetaSP using analog component
    Down convert to Digital Beta using SDI
    Deliver on DVCPro HD tape
    Deliver on HDCam or D5 to a dub house
    Deliver on DV tape for dubbing at the broadcast station
    Use of an online delivery solution for broadcasters
    All of these solutions could have an impact on your needs.
    My suggestion would be to talk a consultant to discuss your needs, answer your questions, and help find out what the issues are. Alternatively, talk to ProMax. They put systems together for a living.
    What follows is a list to get you started at the high end of what you describe. You should be able to scale back once you know what the work flow would be. I may have left out a few (or more) things here, so be sure to hire an engineer or system integrator like ProMax to put all of this together. I included both a tower and a laptop to give you the flexibility to work on location or do demos in client offices.
    A top end maxed out Mac Pro with a Kona 3 card
    A top end MacBook Pro with an IO HD
    An SATA or Fibre Channel Array from Ciprico or CalDigit or Sonnet or Dulce or fill in the blank
    A very good external RAID from LaCie or G-Tech or similar and an ExpressCard adaptor to connect it to the MacBook Pro
    The best CRT you can afford (Sony 14 or 20″ L5)
    A very good LCD for monitoring HD. Search all over the Cow for recommendations.
    External Scopes
    Very good near field monitors (Yamaha, Genelec, Tannoy, etc)
    An appropriate sub to go with the near field monitors
    A mackie mixer to route your audio sources to the monitoring.
    The cabling for the tape decks or similar you are going to need for capturing and outputting
    The tape decks you need to buy, or budget to rent or outsource.
    UPS to protect against power failure.
    Best wishes,
    Tom
