Activity Forums Apple Final Cut Pro Legacy Help-Video is pixel hell!
  • Help-Video is pixel hell!
    Posted by Wally on June 3, 2007 at 4:11 pm
    I received some video for a film that was in Animation codec. Now, when I put it in FCP I am getting “shadow pixels” when there is movement. Is there anything I can do to correct this?
    Thank you
    Wally
    Russell Lasson replied 19 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Russell Lasson
    June 4, 2007 at 1:21 pm
    I’m not sure I understand the problem that you’re having.
    Does the file have an alpha channel? If so, is it straight or premultiplied?
    -Russ
  • Wally
    June 4, 2007 at 7:21 pm
    I found out that the real problem I’m having is the same I realated to you in the other post. There is difficulty with the footage when I put it in the time line and it shows the pixels in the Canvas. It is perfect in the viewer. I am confused to say the least. I now have the original footage and will be logging and capturing it again. I will let you know how it turns out. In the mean while, do you have any ideas?
    Wally
  • Russell Lasson
    June 4, 2007 at 8:38 pm
    What are your timeline settings? Is your canvas set to view at 100%? (If not, it never really represents what your video looks like)
    Setting up a timeline to the Animation compressor isn’t a regular practice. It would really help if you explained your workflow a little more.
    -Russ
  • Wally
    June 4, 2007 at 9:13 pm
    Russell,
    Could you please explain what you mean by workflow?
    Wally
  • Russell Lasson
    June 5, 2007 at 1:25 am
    Yeah, no problem.
    What was your show shot on? How did you digitize it? How did you get it into the animation format? What graphics/effects are being done and on what system? How will you view or deliver the final video?
    Workflow is beginning to end of the project. It’s usually a very good practice to plan and test your workflow before you begin a project. (way too many people don’t and they end up with some pretty nasty problems and super tight deadlines).
    -Russ
  • Wally
    June 6, 2007 at 9:51 am
    Thanks for all your help Russell. I followed one of your questions and investigated the original footage and found that most of it was ripped from a DVD and saved in “iMovie”, why I don’t know. I did not know about this until I went back to check it out. I re-ripped the footage and everything is back on track.
    Again, thank you for your help. I would still be fooling around without your advice instead of going back to the source.
    Thanks again,
    Wally
  • Russell Lasson
    June 6, 2007 at 2:05 pm
    Glad you got it figured out!
    -Russ
