Activity Forums Boris FX Particle Illusion Help using particle illusion with element 3d
  • Help using particle illusion with element 3d
    Posted by Sarah Cain on February 19, 2021 at 2:47 pm
    <div class=”cooked”>
    to make things super simple and easy I will
    create an imaginary scene so that you guys can get a good understanding
    of what am trying to archive.
    1: new comp
    2: 1 solid added
    3: add element 3d and put an airplane to the scene.
    4: back to the main AE, solid, effects of element 3d
    5: utilities / generate 3d position and added point to airplane turbines.
    6: new solid / particular illusion.
    now how do i attach P,I to the 3d null am stuck
    https://vimeo.com/513632516
    </div>
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Sarah Cain replied 5 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
