Activity Forums VEGAS Pro Help-uncompressed render=wrong par
  • Help-uncompressed render=wrong par
    Posted by Abraham Marquez on July 23, 2009 at 4:15 am
    Dear Vegas users,
    i have been using Vegas pro 8.0 for 2 years now rendering projects uncompressed Avi 720 by 480 par 9.091 with no problems .but now when i render my project uncompressed Avi it is being uncompressed in a square par 1.000.
    to troubleshoot i rendered in another avi codec with avi dv compression and it comes out with the correct par,so the uncompressed codec is the culprit.
    im not a complete novice with the software but it seems i have reset setting or something similar.
    thank you in advance.
    Abraham
    Abraham Marquez replied 17 years, 1 month ago 2 Members · 4 Replies
  • Rob Strobbe
    July 23, 2009 at 4:36 am
    Not clear here: Have you clicked Custom and made sure that the video tab has the correct PAR, but the file doesn’t render with it? Or are you just choosing the Uncompressed template and trusting that it lists the correct PAR? Possible that at some point your template got changed, and Vegas is just using the settings that are there. If that’s the case, just correct the PAR there and hit the Save button next to the template name (in the Custom Template dialog).
    Rob
  • Abraham Marquez
    July 23, 2009 at 6:52 am
    sorry for not being clear.in the custom tab for par is the set par i need so that isn’t the problem.And no i am not just using the uncompressed template.im using a custom template i used before over and over again with desired results but i dont know why this is happening.
    is there another way to render out as close as uncompressed in quality?
  • Rob Strobbe
    July 23, 2009 at 6:53 pm
    Can’t think of a reason why you would be getting new results from a previously working template. Where are you seeing the incorrect PAR?
    Rob
  • Abraham Marquez
    July 23, 2009 at 7:58 pm
    i see the avi file in the different par which is in square par 1.000 on the media player and also when i drop it into a vegas project timeline which has the par i need, which is 9.098.
    i have put the same thread in another forum and they say it is a long standing bug that vegas has ignored fixing but what i dont understand is that this process has always worked for me before and all of a sudden it doesnt.
    do you know if there is any updates for vegas pro 8.0 that will update without going online because of the fact my pc is an offline workstation.
    i can download software though from my laptop.
    thank you
