Activity Forums Adobe After Effects Expressions Help tweaking an expression
  • Help tweaking an expression
    Posted by Michael Mazur on May 1, 2007 at 3:01 pm
    Here is the expression that I am using…
    amtOfDigits = 2;
    seconds = Math.round( time % 60 );
    minutes = Math.floor( time / 60 );
    function addLeadingZeroes( v ){
    for( i = 0; i < Math.abs( amtOfDigits - (v + "").length ); i++) v = "0" + v; return v; } addLeadingZeroes(minutes) + ":" + addLeadingZeroes(seconds) My only problem is that when I get to the 1:00 minute mark in the timeline the seconds count to :60 for a half second before switching over to 1:00. Obviously , I want the seconds to count from :59 to 1:00 directly. My comp setting is an HD 30fps set-up right now. Please help.
    Dan Ebberts replied 19 years, 4 months ago 2 Members · 3 Replies
  • Dan Ebberts
    May 1, 2007 at 3:18 pm
    Try changing the second line to this:
    seconds = Math.floor( time % 60 );
    Dan
  • Michael Mazur
    May 1, 2007 at 4:10 pm
    Thanks so much man that was it. If you get a second can you explain to me why that fixed it?
    What is the difference between floor and round?
    Thanks again.
  • Dan Ebberts
    May 1, 2007 at 5:22 pm
    Math.round() rounds to the nearest integer value, which could be up or down, while Math.floor() always rounds down.
    Dan
