Activity Forums Adobe After Effects Help! Trying to export AI layers into psd…
  • Help! Trying to export AI layers into psd…
    Posted by Jennifer on May 15, 2006 at 9:13 pm
    Can anyone help me with this? I need to take files built in layers in ai and export them to psd. When I do this, psd combines some of the layers and I cant separate them. Am I doing something wrong? I’m a little desparate because I have a lot of files to transfer.. if anyone knows how to fix this, your help would be much appreciated! Thanks in advance,
    Jen
    Joe Hayden replied 20 years, 3 months ago 2 Members · 1 Reply
  • Joe Hayden
    May 16, 2006 at 1:50 pm
    Hello Jennifer,
    I’m not sure why you posted this in the After Effects forum.
    If AI stands for After Effects instead of Illustrator then under the composition menu>Save Frame as Photoshop Layers.
    Often I open an Illustrator file in After Effects as a composition and Save Frame as Photoshop Layers as described above.
    If you don’t have After Effects and this doesn’t help, try the other forum (Photoshop/Illustrator).
    Cheers,
    Joe
