Activity › Forums › Adobe After Effects › Help! Trying importing Photoshop layers into after effects.
  • Help! Trying importing Photoshop layers into after effects.
    Posted by Video Wizard on January 29, 2007 at 5:29 am
    I am trying to take a 24 layer file from Photoshop and import them into After Effects to be used as a movie. When I do it shows each layer for one frame. I need it to show each layer for about 6 frames. Where and how do I change that?
    Would greatly appreciate any help you can provide!
    Thank you!
    Bill
    Mylenium replied 19 years, 8 months ago 3 Members · 2 Replies
  • Iancorey
    January 29, 2007 at 6:51 am
    Open the comp that was created when you imported the PhoSho file and press Cmd/Ctrl K. At the bottom is the length of the comp. Press 6, Enter.
  • Mylenium
    January 29, 2007 at 8:32 am
    Unless otherwise specified, still layers have an infinite duration. Import your PSD as a comp, set the out-point of all layers to 6 sec, then stagger them using the Sequence Layers keyframe assistant.
    Mylenium
    [Pour Myl
