Activity Forums Adobe After Effects HELP! – trouble with Render>Foam
  • HELP! – trouble with Render>Foam
    Posted by Jay Gray on January 16, 2006 at 8:21 pm
    I was recently going through Mark Simpson’s “How to make a tree grow” with the Lightning effect, and then with the Foam effect. I think its a really cool idea how to utilize those effects. However, I am having trouble with the foam effect getting my source video “leaves.mov” to open correctly under the render tab of Foam. The problem is that when it uses the video to render the leaves, the whole white screen containing the leaves opens up, rather than just the leaves by themselves. So, when i play it back, instead of a bunch of leaves growing, it looks like a bunch of little square screens with leaves in the middle are growing. Does that make sense? Could someone please help me out? This would also be useful for using a source video in the particle playground effect. Thanks!
    Jay Gray replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
