Activity Forums Apple Final Cut Pro Legacy HELP! Transcoding and batch importing lost XDCAM files.
  • HELP! Transcoding and batch importing lost XDCAM files.
    Posted by Annu Lilja on August 31, 2009 at 2:54 pm
    IGNORE THIS IF THERE IS NO WAY TO MAKE AN AVID PROJECT INTO A FCP PROJECT!
    The Lacie raid drive broke which held all the material for my film, and I need to import/batch import all the material again. The technical advisor at the company where I am working says that I cannot batch import the material, because the material that I have been editing was transcoded from the original XDCAM files, and that the AVID project will not recognize the untranscoded files. He says that even if I transcode the files again, I cannot batch import those files because the NEW transcoded files will not be identical to the OLD transcoded files.
    He said that I might be able to do it if I edit on Final Cut, since FCP might recognize the files based on length, but I’m not sure if there is a way to turn my existing AVID project into a FCP project.
    If I cannot batch import the files, I will lose 5 weeks of work, plus I will need to sync the material again, there is 35 hours of it.
    I would be very grateful for any helpful hints.
    Thank you,
    Annu
    Victor Perez replied 17 years ago 2 Members · 1 Reply
  • Victor Perez
    August 31, 2009 at 4:41 pm
    You should be able to batch capture if you have an XDCam deck with SDI out & 422 machine control (PVW-F70 or above) and a capture card with SDI in and 422 machine control.
    If so you can take the deck out of PC remote and run a SDI cable and RS 422 to your capture card. This will turn your XDCam import deck into a player allowing you to capture / batch capture your material. We have done this in SD mode for an older 4×3 project, but have not tried in HD mode.
    hope that helps
    Victor
    http://www.editvictor.com
