Activity Forums Avid Media Composer HELP! Transcoding and batch importing lost XDCAM files.
  • HELP! Transcoding and batch importing lost XDCAM files.
    Posted by Annu Lilja on August 31, 2009 at 2:52 pm
    the Lacie raid drive broke which held all the material for my film, and I need to import/batch import all the material again. The technical advisor at the company where I am working says that I cannot batch import the material, because the material that I have been editing was transcoded from the original XDCAM files, and that the AVID project will not recognize the untranscoded files. He says that even if I transcode the files again, I cannot batch import those files because the NEW transcoded files will not be identical to the OLD transcoded files.
    He said that I might be able to do it if I edit on Final Cut, since FCP might recognize the files based on length, but I’m not sure if there is a way to turn my existing AVID project into a FCP project.
    If I cannot batch import the files, I will lose 5 weeks of work, plus I will need to sync the material again, there is 35 hours of it.
    I would be very grateful for any helpful hints.
    Thank you,
    Annu
    Bouke Vahl replied 17 years ago 2 Members · 1 Reply
  • Bouke Vahl
    September 1, 2009 at 7:56 am
    What exactly did you do on the transcoding?
    If you have transcoded IN AVID and have imported the files file based (rather than digitizing), you CAN do a batch import.
    (This is exactly what i am doing now on a large project with over a hundred disks)
    Just select clips or sequence, select ‘batch import’
    If you see a disk label, you’re golden.
    There are other ways to make it happen as well, but for that i need some more information.
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
