Activity › Forums › Adobe After Effects › help to stop number count
  • help to stop number count
    Posted by Calikat on June 1, 2006 at 11:27 pm
    I’m trying to make ticking numbers count from 0 to 15, and then stay at 15 for the remaining time. I used the Frame Number Expression, and it worked great, except it would not stop counting. I then made a null layer and added a slider control, which makes it stop, but it added a bunch of decimal numbers while it’s counting. I just want the whole numbers. A few other things I tried changed the numbers into a clock, with hours, minutes, and seconds.
    I’m pretty new to AE, but I was assuming this would be an easy fix (and it still might be), but I have run out of options. Don’t know what to try next.
    Would appreciate any help I can get,
    Kat
    Calikat replied 20 years, 3 months ago 3 Members · 4 Replies
  • Enzo Tedeschi
    June 4, 2006 at 11:39 pm
    You could always use a boring old text layer that says 15 for the last frame, then use an expression on that to make it last the length of your comp…?
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Julian Sixx
    June 5, 2006 at 5:50 am
    Hi
    use the effect “numbers”,it’s the easiest way!!!
  • Enzo Tedeschi
    June 5, 2006 at 9:35 am
    Or there’s that…
    ;o)
    Enzo Tedeschi
    Editor
    Sydney, Australia
  • Calikat
    June 5, 2006 at 4:48 pm
    Thanks a lot… I’ll try it 🙂
