Activity › Forums › Adobe After Effects Expressions › [HELP] Time Remap – Trying to create a Script
  • [HELP] Time Remap – Trying to create a Script
    Posted by Vincenzo Imbimbo on May 25, 2022 at 7:27 pm
    Hello guys! I’m trying to create a script that does this:
    Step 1: Enable Time Remap of a precomp ( or all precomps selected)
    The time remap automatically creates 2 keyframes, so…
    Step 2: Go to the last keyframe and go back 1 frame, create new keyframe and delete the last keframe. Example: a precomp of 10 seconds (25 fps) would have a keyframe on frame 0:00 and another keframe on frame 10:00, i want to create a keyframe on frame 9:24 and delete the keyframe of 10:00. I want this to happen no matter what time duration is that precomp and no matter how fps it is, always create 1 keframe before the last one and delete that last one.
    I now how to do step 1, but only works with 1 layer, i don’t know why is the “for loop” not working, and also i’m having trouble with step 2.
    The code that i have right now is this:
    app.beginUndoGroup("My Script");
    var comp = app.project.activeItem;
    var layers = comp.selectedLayers;
    if(layers.length == 0){
    alert("You must select a layer");
    } else {
    for(var i = 0; i < layers.length; i++){
    layers[i].timeRemapEnabled = true;
    var timeRemapProp = layers[i].property("ADBE Time Remapping");
    var times = [0, //i think here goes something like "outPoint - one frame"?//];
    var values = [0, //i don't now what should i write here//];
    timeRemapProp.setValuesAtTimes(times, values);
    app.endUndoGroup();
    Vincenzo Imbimbo replied 4 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 25, 2022 at 8:17 pm
    Something like this maybe:
    var timeRemapProp;
    } else {
    if (layers[i].canSetTimeRemapEnabled){
    timeRemapProp.addKey(timeRemapProp.keyTime(timeRemapProp.numKeys)-comp.frameDuration);
    timeRemapProp.removeKey(timeRemapProp.numKeys);
  • Vincenzo Imbimbo
    May 26, 2022 at 3:46 pm
    Thank you Dan, it works perfectly!
