Activity › Forums › Adobe After Effects › Help. Time indicator not running smooth in my comp window.
Posted by Jamey Kramer on December 1, 2009 at 2:48 amHello friends. I hope you know a solution to my problem.
I am editing a music video and trying to match some transitions to specific drum beats in the song. The problem is that during RAM previews the time indicator does not run smoothly in the comp window which makes is difficult to know if I got the edit right.
The indicator skips and along on every 8th frame during the RAM preview. The video preview works fine.
I am using Adobe After Effects CS3
I recently upgraded my computer to an intel dual core processor with 2 gigs of ram and an nvidea 512mb video card.
On my 7 year old intel P4 computer this was not a problem which makes it all the more frustrating.
Thanks ahead of time!
JameySerge Hamad replied 16 years, 10 months ago 3 Members · 8 Replies -
David Bogie
December 1, 2009 at 3:22 pmAe is a terrible place to edit. do it in Premiere or FCP.
You can easily display your audio waveform in AE. The drums will be obvious. You can place markers on them.bogiesan
Jamey Kramer
December 1, 2009 at 4:37 pmAu contraire AE is an amazing place to edit – if not the best for action type videos. I use Premiere already to chop up the RAW footage then import the project into AE to piece it together.
On a side note to my problem, I’ve figured out how to scrub with the time indicator which is an awesome feature!
Any other suggestions on how to get the timeline indicator to run smooth would be appreciated.
Thanks.
Jamey -
David Bogie
December 1, 2009 at 6:31 pm[Jamey Kramer] “Any other suggestions on how to get the timeline indicator to run smooth would be appreciated. “
If you are comfortable editing in AE you are already be aware there are no magic ways to improve AE performance. You get a better CPU, use lower rez, and learn to work within the confines of your system’s limitations.
bogiesan
Jamey Kramer
December 1, 2009 at 8:01 pmThanks bogiesan for replying but again I disagree.
Adobe After Effects CS3 was working just fine on my 7 year Intel Pentium 4 desktop computer… it just ran a little slower but the timeline indicator (The red vertical bar)in my composition window would run smooth. I like the unlimited possibilities AE presents while editing and it is the program for me.
I have since purchased the new computer I mentioned earlier. System limitations is not the problem. System configuration probably is but I don’t know why or how. This is why i am hoping someone helpful in Cowland might know.
The timeline indicator now skips along in the composition window on every 8th frame during RAM previews. It bugs me because I know it’s not supposed to and it affects my productivity.
Again thanks for replying but I’m still hoping somebody knows why it might be doing that 🙂
JameySome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Serge Hamad
December 2, 2009 at 5:42 amHi Jamey,
In case you are working with a long clip,reduce the duration of your previews by adjusting the work area bar to a minimum. (Whatever is needed to get your work done per beats)
Make also sure that your preview settings are not set to skip frames.
I hope this may help.
Salut.
SergeNew! InvigoMany-Media volume I & II available here:
https://www.nyc-visual.comInvigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
David Bogie
December 2, 2009 at 3:08 pm[Serge Hamad] “reduce the duration of your previews by adjusting the work area bar to a minimum. (Whatever is needed to get your work done per beats)
Make also sure that your preview settings are not set to skip frames”Good suggestions, Serge. But Jamey has declared sufficient experience with After Effects to already know the basics.
bogiesan
Jamey Kramer
December 2, 2009 at 9:51 pmHey thanks for the constructive feedback.
It turned out to be an audio compatibility issue.
The sound card was defective and my computer shop just replaced the entire motherboard for me.
AE is purring like a kitten now.. Awesome!
Take care.
Jamey -
Serge Hamad
December 3, 2009 at 6:26 amYou never know dude! We all thought, We’ve seen it all 😉
Salut.
