Activity › Forums › Apple Final Cut Pro Legacy › Help Time code window opened.
  • Help Time code window opened.
    Posted by Greg Ball on January 24, 2008 at 12:39 am
    All of the sudden all of my playback out of my FCP system shows a timecode window. I’ve never had this before. I downloaded Aja 4.O so I could have Pro Res 422on my system.
    I have a G5 Quad running FCP 6.0.1. I’m editing to Beta SP as 8 Bit uncompressed. My system is a dual boot system with Media 100 Hde on one side and FCP on the other HD. Media 100 Hde came with an Aja OEM card. There’s no settings that I changed in my PVW 2800 but all playback has time code burned in. It’s recording to my deck the same way. HELP!! I have a deadline tonight! It doesn’t show any timecode in the canvas window though.
    Greg Ball replied 18 years, 8 months ago 3 Members · 5 Replies
  • Paul Escandon
    January 24, 2008 at 2:11 am
    I honestly think it has to be your deck that is doing the burn in – as Final Cut Pro has no setting to add timecode like that unless you explicitly add filters and tell it to do that.
    I guess there is a possibility it can be something in the AJA – but on my Kona 3 I don’t remember there ever being a setting to do this.
    If you must, try resetting the deck to factory defaults.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • Matthew Nelson
    January 24, 2008 at 2:15 am
    Also are you sure you’re not monitoring the deck via the composite super?
  • Greg Ball
    January 24, 2008 at 2:38 am
    Thanks guys. No it’s got to be something in the AJA Setting. Like i said nothing has changed with my deck.
  • Paul Escandon
    January 24, 2008 at 2:40 am
    I just checked my Kona 3 Control Panel and there is actually a field where you can add timecode burn in. That’s probably what it is.
    Open your Kona Control panel and click on the Timecode tab. There is a Timecode Burn-In dropdown that you can set to off. Do that and hopefully you’re good.
  • Greg Ball
    January 24, 2008 at 3:34 am
    That was it!!! Thanks so much Paul. Have a great evening!
