Activity Forums Adobe After Effects HELP! This flickering is driving me nuts!
  • HELP! This flickering is driving me nuts!
    Posted by Tee on May 22, 2005 at 11:23 am
    Hi everyone. This is starting to become a recurring problem for me with certain types of footage. When I render out of AE 5.5 or 6.0, I get this “flickering effect” in certain regions of the video field. I’ve attached a link to a sample video file. If you look on the upper area of the roof right under where the guy is sitting, there is a very noticeable flicker. What can I do about this?
    https://www.tntdigitalmedia.com/Comp%206-ATHF_CD.mov
    I export with these settings:
    AVI
    No Compression
    24 fps
    Million + color
    Someone please help. It’s starting to really get on my nerves! 🙂 THANK YOU
    Tee replied 21 years, 3 months ago 3 Members · 4 Replies
  • Andrew Yoole
    May 22, 2005 at 11:54 am
    You are seeing interlace flicker, which can be caused in a number of ways. How is you’re footage captured? I suspect it’s from an interlaced camera source, possibly a DV camera. The mismatch of interlaced source and non-interlaced output is tricky, and the best way to overcome it is to deinterlace the source footage. The best way to deinterlace your footage is with Magic Bullet (at a hefty price)
    https://www.redgiantsoftware.com
    but you can also use the free plugins on offer from Pete Warden
    https://www.petewarden.com
    You can also deinterlace footage in a NLE like Premiere Pro or Final Cut Pro.
    Don’t confuse deinterlacing with field interpretation. If you interpret field order and render frames, you’ll actually just remove one field from the source footage (which is harsh deinterlacing). If you interpret source footage as frames, you’ll end up with flickering like what you’re seeing now.
  • Steve Roberts
    May 22, 2005 at 12:54 pm
    [Andrew Yoole] “If you interpret field order and render frames, you’ll actually just remove one field from the source footage (which is harsh deinterlacing).”
    Technically, AE only does that if the layer is set to draft quality. At high quality, AE interpolates between the frames. Admittedly, it isn’t smart enough to avoid doing this in areas where there is no motion. RevisionFx’s Fieldskit plugin is supposed to do this intelligently.
    Note: sometimes a 1-pixel vertical blur (directional blur or fast blur) can soften fine lines to avoid flickering … but you need to interpret the footage as fields to make that work.
    Why 24 fps?
    What was your final frame size?
    What was your final goal? DVD?
    Did you render to fields? Why? (You don’t have to, but if you do, get the field order right.)
    You should also get Trish & Chris Meyer’s books, Creating Motion Graphics. They’re must-haves.
    Steve
  • Tee
    May 22, 2005 at 10:10 pm
    Thanks guys,
    The reason for 24p is because I shot in 24 on the DVX100. The dropdown will change and final output is 29.97. But the DVX100 24p emulates the look I want. Also, I failed to mention, I had already deinterlaced the footage in Premiere Pro, but to no avail. I will fiddle around with the blur remedy and see if that works. Thanks!
  • Tee
    May 22, 2005 at 10:41 pm
    I fixed it! I applied Field Interpolation. No need to de-interlace since the footage was already progressive. I also added the Broadcast Colors filter and it cleaned things up a bit too.
