Activity Forums Adobe Premiere Pro Help: Steps to export my project to Encore
  • Help: Steps to export my project to Encore
    Posted by Hector Melendez on December 6, 2008 at 4:51 am
    Has been working with PP CC2 & 3 & think have a good knowledge… but I’m using CC4 for the first time. Have a project of 2 hrs in the timeline but can’t find the way to export in order to be imported into Encore. (In CC3 it say “Export movie” but not in CC4)
    I watched Lynda tutorial, have read several post but still don’t see how. When following the tutorial in the last step, bar start running but almost immediately stop and seems like hanging up. No time running or anything else. Either can’t find Microsoft DV-AVI as a preset.
    Trying to using the logic flow but still nothing!
    Very disappointed with this program. Looks like a different animal; not an upgrade!
    Please help me to complete the last phase of this edition to erase CC4 for ever.
    Peter Berthet replied 17 years, 9 months ago 3 Members · 9 Replies
  • 9 Replies
  • Mike Velte
    December 6, 2008 at 12:02 pm
    File>Adobe Dynamic Link>Send to Encore
  • Hector Melendez
    December 6, 2008 at 6:27 pm
    This didn’t work, Mike. It freeze up at 50% when a window “Import Premiere Pro Sequence” show up. I leave it running for over an hr and the status didn’t change despite I see some HDisc activity any other time. Could be its working but how do I know? Its taking more time that I used to see in CC3. What next?
    Between each try I have to power down the PC. It freeze it up. However I could export one of the 3 timelines by exporting media procedure. I selected Microsoft avi, simulating the same as in CC3 default.
    Due to all of this problems I don’t want to use Encore CC4. Its better to stay within a known prog.s like Encore CC2 or CC3. This is a long project & want it to finish it ASAP
    thanks
  • Peter Berthet
    December 8, 2008 at 2:50 am
    make sure your work area bar is ok
    file>export media
    choose your export settings
    h.264 for dvd will mean that encore wont need to transcode
    hit ok,
    adobe media encoder will open up with the file and presets that you chose
    if you need to make any changes to your export you can go into more detailed settings here
    once your done with your settings, hit “Start Queue”
    the file will be exported with the settings you chose
    then simply go into encore and import the file
    thats it 🙂
  • Hector Melendez
    December 8, 2008 at 3:41 am
    Thanks Peter
    Did it this way and was able to make the transcoding only that it takes more time than CC3 to make it because it first takes about 1hr to load the project before starting the transcoding… weird (not an advance in this version)
    Arouse to me whats the best set-up to make the trancoding because I don’t want to make multi-transcoding and lost quality because anyway Encore makes his own to get it fixed into the DVD
  • Peter Berthet
    December 8, 2008 at 5:34 am
    i understand the ‘best’ way is to bring in raw video and allow encore to transcode the videos, as it fits them using the best compression for your individual project.
    the way i desribed above is a standard h264 export which could potentially offer poorer results, although ive yet to see a serious difference
  • Hector Melendez
    December 8, 2008 at 5:30 pm
    UPDATE
    I was able to make the timeline transcodings to be use by Encore. (avi files)
    I don’t understand why this changes are made if the final result is the same. Its like go to Walmart one day and find out they have change the lay-out. You got crazy finding the stuff you were accustomed to buy.
    CC4 takes more time to render… can’t export a frame as before..can’t monitor out my Timeline, difficult to export timelines an so on.
    Users have to weight the benefits or new features vs the extra time needed to execute the same common tasks.
  • Peter Berthet
    December 8, 2008 at 11:36 pm
    just out of interest what sort of system are you running, so far the experience ive had with CS4 is that its been faster to complete most tasks than cs3 (certainly crashes less)
    ~Peter Berthet
    Sydney, Australia
  • Hector Melendez
    December 9, 2008 at 2:58 pm
    Well Peter, its an HP dual core 4200 AMD with 3g ram, and an Nvidia 7300 GTS, 256ram. All raw and scratch discs are external HD (2 of 500g ea) plus another 250g internal sata to store the transcodings)
    This Pc works flawlessly with the others PP versions.
  • Peter Berthet
    December 10, 2008 at 7:17 am
    yeah , in that case definately odd that your getting poor performance
    i was running some tests doing the same thing you described on a laptop that isnt even close to the spec of your system and it ran fine.
    ~Peter Berthet
    Sydney, Australia
