Activity › Forums › Apple Final Cut Pro Legacy › HELP! Speed problems when exporting
  • HELP! Speed problems when exporting
    Posted by Gemma Harris on November 10, 2009 at 9:20 pm
    Hi everyone. I’m still very new to final cut pro and i have a problem with some of my clips.
    When i imported my clips into the program and then put them onto the timeline, the clip was out of synch with the audio. I can only assume because the frame rate was i think 38 fps (i know! an odd number but that’s what it was) and the timeline was 24 fps.
    Anyway… i changed the speed of the image so that they synched perfectly with the audio when previewed in the viewer.
    However…as soon as I exported it as a quicktime movie the image is too slow again but the audio is correct. It’s the same when i render the whole piece.
    So i thought i could just change the speed of the video image back to 100% but it keeps coming up with the message ‘a conflict occured during a trim operation.’ I read on other forum that i should move this clip to the end of the timeline and it should work. Is this true?
    Please, please, please help! (i need an answer within the next 12 hours)
    Waldo Capote replied 16 years, 9 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    November 11, 2009 at 6:26 pm
    what is the source of this errant clip? 38fps? that’s a new frame rate!
    You can just put it in a sequence all by itself, change the speed, then cut back in to the “master” sequence, but it may not fix you up on the export at all. The errant clip is likely the problem. What is this clip, and where was it originated? Tape? Export from another app or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Waldo Capote
    December 23, 2009 at 4:33 pm
    Hello Gemma,
    I’m having the same problem. Did you find any solution?
    thanks,
    Waldo Capote
