Help sound clips dont work after export.
Posted by Erik Aalto on March 25, 2009 at 12:34 amI’m new to Vegas so I have no clue what’s going on. Everytime I export my video, my sound clips I used don’t work. Can someone help me?
Erik Aalto replied 17 years, 5 months ago 3 Members · 9 Replies -
John Rofrano
March 25, 2009 at 2:36 amWhat format are the sound clips?
What format are you trying to export to? (by “export” i assume you mean “render”)
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Erik Aalto
March 25, 2009 at 3:46 amyes render sorry. they are mp3, and i dont know which is better to use, .avi or .wmv?
John Rofrano
March 25, 2009 at 2:37 pmMP3 files should be fine regardless of what format you are rendering to. As an experiment, try rendering just the MP3 file to WAV and then use the WAV file in your project and see if that works. I’ve used lots of MP3 files in my projects and have never had any problem rendering.
~jr
John Bollenbacher
March 25, 2009 at 5:21 pmErik-
What do you mean that they don’t work? I have used .mp3s all the too, and not had problems.
Is it just not there? Or is the audio distorted/corrupted??
If you go to “render as” and don’t change any settings the audio should render out with the video automatically; but you can go in to the custom settings and not render out the audio. It could be possible to have the audio unchecked from a previous render and if you don’t change it back, it could keep ignoring your audio.
John Bollenbacher
10engines -
Erik Aalto
March 25, 2009 at 10:50 pmwell i chose render as and never changed any settings. it rendered as .avi, but again when i watched it, i could not hear the .mp3 sound clips.
John Rofrano
March 26, 2009 at 2:02 amDo you hear other audio and just not the MP3’s? or is there no audio at all?
~jr
John Rofrano
March 26, 2009 at 11:08 am> i hear the other audio just not the .mp3s
Wow, that is strange! Try rendering the MP3’s to WAV files and see if that fixes the problem. I can’t imagine why it’s not working though.
~jr
Erik Aalto
April 1, 2009 at 7:05 pmwell i did render the the video as .wav and they worked this time but since it was a .wav there was no video.
