Activity › Forums › Sony Cameras › help sought with XD CAM Transfer!
Posted by Luc Majno on June 16, 2008 at 5:15 pmGood day! Now it is ME that needs your help, folks, and I am not ashamed of telling you my mistake… Uh… Well,… here goes. I transferred all my images, video from the EX1 straight off the camera using XD CAM Transfer… Not a problem, until I wanted to put them back on the camera a few months later… It will recognize the ‘folder’ as a hard drive would, but it will not play the videos.
I am told this is because it cannot read Mpeg2… I have Final Cut Pro, and I can take the clips and change them into other formats, no?H E L P .
Thanks, Yall…
Michael Palmer replied 18 years, 3 months ago 3 Members · 14 Replies -
Michael Palmer
June 16, 2008 at 5:28 pmIf you just copied the original BPAV folder during this transfer then you should be able to copy it back on to the card. If you used the XD Cam Transfer program to re-wrap the files as .mov and you didn’t save the original BPAV file then the camera won’t understand what to do with the QuickTime .mov file. Perhaps you can find a program to transcode back to MP4, or you may need the new PMW EX-30 deck that will encode any HD-SDI signal as XD Cam EX 35Mbps. What is the purpose for this?
Good Luck
Michael Palmer -
Luc Majno
June 16, 2008 at 5:34 pmHello and thanks for the speedy reply… I simply moved all the clips off the cards via XD Cam Transfer, thinking I could put them back on again with no issues… I was wrong. All this is so «i can keep track of the seasons, using the camera’s image-overlapping mode to line the image up. I guess I will have to re-convert the files into Mpeg4, as you suggest?
Michael Palmer
June 16, 2008 at 5:43 pmHow did you move the clips off the card? The proper way is to copy the BPAV file to a separate folder. This keeps all the files the camera needs to play the original XD cam EX clips.
Good Luck
Michael Palmer -
Luc Majno
June 16, 2008 at 5:53 pmI simply, without knowing any better, moved them, transferred them to hard drive using XD Cam Transfer, and them deleted them, sometimes more than one clip at a time, using the XD Cam Browser software…
Michael Palmer
June 16, 2008 at 6:14 pmJust to be clear when you say moved them (because that isn’t really possible) you either converted the original .MP4 file to a QuickTime .mov and then deleted the original files from the card, or you copied the .MP4 clips and deleted the original files from the card. These threads help others and it is important to include all the details.
Good Luck
Michael Palmer -
Luc Majno
June 16, 2008 at 6:18 pmI am sorry. Yes, the proper word is IMPORTED. With XD Cam Transfer software, I IMPORTED the files onto the HDD. Then, I deleted them from the card afterwards.
Luc Majno
June 16, 2008 at 6:22 pmForgive me, but I am not sure that I understand. You say the best way is to copy the BPAV folder to the HDD. But then the originals stay on the camera? Isn’t the idea to off-load the clips to empty the card? You copy the folder and then delete it from the card?
Don Greening
June 16, 2008 at 6:42 pm[Luc Majno] “You say the best way is to copy the BPAV folder to the HDD.”
Correct.
[Luc Majno] “But then the originals stay on the camera?”
Yes, until you delete the media from the card.
[Luc Majno] “Isn’t the idea to off-load the clips to empty the card?”
Correct.
[Luc Majno] “You copy the folder and then delete it from the card?”
Tht’s right. You can make an exact duplicate of what’s on the card. Highlight the card icon on your desktop, choose “open”. There is one folder in there called the BPAV folder. Drag that to any other hard drive to copy it. Once the copying is complete you can drag the original BPAV folder on the card to your computer’s trash bin to empty the card. Then you can start the Sony Transfer Tool, navigate to your copied BPAV folder and transcode the native MP4 files to MOV files for editing. If you leave the copied BPAV folder alone (without altering anything inside it) you can always copy that BPAV folder back onto the card for later use with the EX1.
– Don
Luc Majno
June 16, 2008 at 7:24 pmSo, if I am correct, by doing so, by putting the folder back on the card, it will replace the existing one on the card already? Please elaborate… or should I simply go and read the camera’s owner’s manual? 🙂 Sorry for all the inconveniences…
Luc Majno
June 16, 2008 at 7:29 pmOh yes, and just one more thing…
If you could please help me a little further along with my conversion issue and to put the clips back on the card? That is a real big one for me. Thanks.
