Activity Forums Adobe After Effects Help setting memory for a x64bit OS.
  • Help setting memory for a x64bit OS.
    Posted by Mark Dalzell on May 6, 2008 at 3:08 pm
    Hi Guys,
    I recently upgraded to Windows XP Pro x64bit. I noticed that when AE CS3 boots up, it’s still only using 2Gbs of memory.
    I read on a GridIron forum that: “Although After Effects is a 32-bit application and is limited to the amount of memory that it can access (2 GB on 32-bit Windows, 3 GB on Mac OS X and 4 GB on 64-bit Windows)”…
    Can someone please tell me how to get AE to see 4GB of memory?
    I have Nucleo Pro 2 installed but there are times when I really don’t need to use it (for short renders). I would like to have AE use the 4GB availble on my x64bit machine.
    Thanks very much.
    Regards.
    Mark Dalzell
    PC Specs:
    VisionDAW 4U 8-Core Xeon Workstation
    2 Intel QUAD-Core Xeon 5365-3.0GHz, 8MB, 1333MHz Processors
    16GB 667MHz Fully Buffered Server Memory Modules (2x2GB)
    Microsoft® Windows® XP Professional x64 Edition
    WDC 250GB, Ultra ATA100, 7200 rpm, 8MG Buffer Main OS HD
    MOTU 24 I/O (main) / MOTU 2408mk3 (slave)
    2 WDC 750GB, SATA II, 7200 rpm, 16MG Buffer HD (Samples)
    Plexor PX-800A 18X Dbl. Layer DVD+/-RW Optical Drive
    Front Panel USB Acess
    Integrated FireWire (1394a) interface
    Thermaltake Toughpower 850W Power Supply
    Dual ESATA Bracket
    2 WWDC 750GB, SATA II, 7200 RPM, 16MB Buffer HD (Raid 0)
    3xUAD1 Universal Audio Cards
    EVGA NVIDIA GeForce 9600GT, 512MB,
    PCI-Express, DUAL-DVI Video Card
    Dual 25.5″ Samsung 2693HM LCD HD Monitors
    Mark Dalzell replied 18 years, 2 months ago 3 Members · 5 Replies
  • Mark Dalzell
    May 6, 2008 at 9:50 pm
    Disregard. I got it.
  • Pat Jaeger
    May 7, 2008 at 6:47 am
    you do know that you can get after efftecs to use all 16GB of your RAM by enabling multiprocessing dont you? If not then you can set after effects to use a certain amount of RAM per core (usually 2GB per core i think) and it will render multiple frames simultaneously.
  • Mark Dalzell
    May 7, 2008 at 2:33 pm
    Pat,
    Thanks for taking time to reply. Yeah, I’m hip to the Mulitprocessor in AE. I have Nucleo Pro 2, therefore I’m not
    engaging this feature at the moment.
    Best.
    Mark
  • Don Logan
    July 18, 2008 at 3:35 am
    you can get AE to see and use 16GB RAM? Please do tell? I thought it was still a 32 bit application.
    Don
  • Mark Dalzell
    July 18, 2008 at 8:56 pm
    Don,
    Under preferences, multiprocessing tab, give you a description about
    this. I have Nucleo Pro 2 installed. This runs as a plugin inside
    After Effects. I utilized all of your CPU and RAM. It’s not cheap but
    if you’re a power user, you may want to check it out.
    I’m not sure exactly if AE utilizes all the systems resources like NP2 does. But I have Dual Quad Core Zeon 3Gb Processors and 16GB of Ram installed. NP2 uses all of it.
    Hope this helps.
    Mark
