Activity Forums Apple Final Cut Pro Legacy HELP – SD B-Roll Cut with mixed format timeline
  • HELP – SD B-Roll Cut with mixed format timeline
    Posted by Rc Maples on February 13, 2009 at 6:30 pm
    Hi all,
    I’m cutting some b-roll to be used on a national talk show. I just talked to their editor and the tape I originally sent them has some field dominance issues. The current sequence in question has 2 formats, HDV and DVCPro SD. The Final output is DV NTSC.
    In my timeline, I have the HDV files scaled up to fit full frame (67% original) cut in with the DVCPro footage…. Here’s the problem, the HDV shots are Upper Field First dominance and the DVCPro SD shots are Lower Field First.
    What do I need to do to the sequence to do a print to tape that doesn’t have field flicker? I know that DV NTSC is LFF. Do I just need to do a -1 field shift filter on the HDV clips or what?? I’m under a massive time crunch as their show goes to tape on Tuesday or Wednesday next week and I can’t get any more tape over nighted to them after this afternoon….
    Please help, and thanks in advance!
    Rob
    Doobie Doobie Doo
    beware the penguins
    Adam Paez replied 15 years, 6 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    February 13, 2009 at 7:03 pm
    Your HDV clips should have a shift fields filter on them. Do they?
  • Rc Maples
    February 13, 2009 at 7:08 pm
    Yes they did. It was a +1 Field Shift… But they still flickered when being previewed through our SD deck/monitor.
    I just output a tape changing all the +1 shifts to -1 and that seems to have cleared it up… Does this make sense?
    Doobie Doobie Doo
    beware the penguins
  • Jeremy Garchow
    February 13, 2009 at 7:13 pm
    Sure. Whatever looks best. Also make sure that the y value in the center property of the motion tab is on a whole even number.
    Jeremy
  • Rc Maples
    February 13, 2009 at 7:14 pm
    Alright, thanks Jeremy for the help. Now the PR department won’t be asking for my head 😀
    Doobie Doobie Doo
    beware the penguins
  • Adam Paez
    March 1, 2011 at 1:01 am
    I have a similar problem.
    I have a timeline that is 720p25 and I have mixed in some DV PAL footage. Will I need to mixdown the video in some way to make it layback correctly to tape?
    I am going to layback to 720p25 HDV tape (miniDV).
    I think the progressive vs. interlaced footage might be an issue.
    Thanks.
  • Adam Paez
    March 2, 2011 at 3:58 pm
    I’m sorry….maybe I shouldn’t have posted in here? I just searched and saw that our problems were so similar. Please tell me if I should just start a new post next time. I’m kinda new to this whole forum thing.
    Adam
