Activity › Forums › Adobe After Effects Expressions › [HELP] Script to convert all expressions into keyframes
  • [HELP] Script to convert all expressions into keyframes
    Posted by Vincenzo Imbimbo on March 28, 2022 at 4:01 pm
    Hi! I’m trying to create a script that converts all the expressions to keyframes, i have a bunch of layers with expressions in the “Position” property, and i need to convert it to keyframes.
    I found this post: https://creativecow.net/forums/thread/bulk-convert-expressions-into-keyframes/ where Dan wrote a code but i’m trying to run it and i get this error:
    Syntax error in line:
    app.executeCommand(app.findMenuCommandId(“Convert Expression to Keyframes”));
    This is the code by Dan:
    (Dan if you are reading this pls help me!)
    function convertToKeyframes(theProperty){
    if (theProperty.canSetExpression && theProperty.expressionEnabled){
    theProperty.selected = true;
    theProperty.selected = false;
    var myComp = app.project.activeItem;
    if (myComp && myComp instanceof CompItem){
    var myLayer;
    var myProperty;
    app.beginUndoGroup(“convert expressions”);
    for (var i = 1; i <= myComp.numLayers; i++){ myLayer = myComp.layer(i); try{ myProperty = myLayer.property("position"); convertToKeyframes(myProperty); }catch(err){ } try{ myProperty = myLayer.property("anchorPoint"); convertToKeyframes(myProperty); }catch(err){ } try{ myProperty = myLayer.property("rotation"); convertToKeyframes(myProperty); }catch(err){ } try{ myProperty = myLayer.property("scale"); convertToKeyframes(myProperty); }catch(err){ } try{ myProperty = myLayer.property("opacity"); convertToKeyframes(myProperty); }catch(err){ } } app.endUndoGroup(); } }
    Bulk convert expressions into keyframes
    Vincenzo Imbimbo replied 4 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 28, 2022 at 4:32 pm
    Unfortunately, a lot of the code posted before this site did its most recent upgrade got mangled in the upgrade process. It’s usually where straight quotes get replaced with smart quotes and hyphens get replace with em (or en ?) dashes. In any case, try this cleaned up version:
    app.executeCommand(app.findMenuCommandId("Convert Expression to Keyframes"));
    var myLayer;
    var myProperty;
    app.beginUndoGroup("convert expressions");
    try{
    }catch(err){
    }catch(err){
    try{
    }catch(err){
    }catch(err){
    try{
    }catch(err){
    app.endUndoGroup();
  • Vincenzo Imbimbo
    March 28, 2022 at 4:43 pm
    Thank you so much Dan! This is exactly what i needed, you are such a pro!
