Activity Forums Adobe After Effects HELP! Sawtooth clip…
  • HELP! Sawtooth clip…
    Posted by Brian Dugan on May 27, 2008 at 7:55 pm
    Hey, I have a stock video/animation that is PAL 720 x 540 25fps which looks great when I play it directly in Quicktime. However when I put it into AE it becomes sawtoothed edged, also when I render it out same thing. Even at 100%. What can I do?
    Thanks, Brian
    Brian Dugan replied 18 years, 3 months ago 2 Members · 4 Replies
  • Jason Milligan
    May 27, 2008 at 8:27 pm
    Is the original footage interlaced?
  • Brian Dugan
    May 27, 2008 at 9:12 pm
    Geez, I don’t know, (I’m a little lacking in that department).
    It’s compressed with Apple’s Photo-jpeg codec.
    Got it from iStock, they don’t mention fields etc…
    https://www.istockphoto.com/file_closeup.php?id=000002586305
    Thanks very much for your thoughts,
    Brian
  • Jason Milligan
    May 27, 2008 at 9:20 pm
    It’s says 25P so it should be progressive-scanned (not interlaced).
    Look in your interpretation settings for your video and see if AE is treating it as interlaced and trying to de-interlace it. In other words, right-click (ctr-click) your video and choose interpret footage>main. Make sure where it says “separate fields” is off.
  • Brian Dugan
    May 27, 2008 at 9:25 pm
    OK will do. Thanks.
    I have to run out but will give this a go later.
    Would you mind if I contacted you again on this board tomorrow if I run into a snag?
    Either way thanks!
    NBrian
